Thread: 18SF rehab
Old 03-31-2013, 08:54 PM
erebus erebus is offline
Originally Posted by dginge View Post
2 questions
What are you painting the coffin box? Isn't it gelcoat?
Tank doesn't care if.its painted. I'm in the same boat you are right now. With my fuel tank out......
I painted it with 2 coats of white bilge-Kote.
And I know the tank doesn't care if its painted or not and that nobody will ever see in there, but can't seem to help it.
Lets chalk it up to a bit of OCD.
Also. Just curious about live well.... I was thinking of doing that too.
If you seal the hatch of real well and put a drain hole at the bottom that flowed into the bilge why would it matter if i fish hatch t was ere or not? If.its sealed tight at the deck them water can't get in and if it.did it would drain to bildge and then out with the pump? Help me not make a.mistake
I cut the live well out because I wanted the storage, and better access to the bilge-pump, transom drain-plug and lower engine mount bolts.
Cut it out pretty easy, then glassed in some pre-fab FRP angle around the opening to make a lip. Modified the existing hatch to sit on top of the lip. Should be pretty water tight in most conditions, without the need for any screws or gaskets or sealants. I hinged the lid too, so it can be opened pretty easily too.
Zachary
