Old 04-05-2013, 08:44 AM
fdheld34 fdheld34 is offline
Sounds like a good plan but I would do the walls while you have the chance....
Rolling and tipping etc is easy enough to do.
I have used Interlux Perfection (2 part) system with good results...approx $70 quart.
I have also used Pettit Easypoxy with their white undercoater (primer) with good results as well...usually $25 for the primer and $35 for topcoat.
Also, alot of people have used signature paint and sterling paints with good results....
If you are close to West Marine search on line for cheapest of above Interlux Perfection and Pettit Easypoxy and print out the pricing on line...bring in to West Marine and they will price match it!
Will be an easy do it yourself project..just prep, remove as much hardware as possible and use blue painters tape to tape things you dont remove
Fred
