Thread: 76 23 restore
  #67
Old 04-07-2013, 09:58 PM
martin martin is offline
Well looking for a bracket... But still not giving up yet on the other one... Checking oven range.. Going to try to temper tjis bracket... If it still looks like. Bracket when the quench is done then i will use it.. Stay tuned for an exciting event...
Anything has got to be more exciting then fairing the stern... That is where i am at now... Almost done.... Then off to primer545 and then a high build allthe way around....
Then545 and color.. Sanded hull and filled pin holes and scratches with lw fair.. By awl grip noticed a couple dry spot and delamination.. Of gel coat and mat.. Ground and filled with epoxy....
For the record.?" I WILL Never cut off another transom skin again.... not in this life time
