Thread: Splash day
Old 04-14-2013, 06:42 PM
That's not as terrible as you think (to me, with a lower power 4 stroke). I get those numbers with a yamaha F100 on a 20 master angler with a 13" x 15" pitch 4 blade and a hydroshield. Probably similar prop RPM, higher engine RPM, as I have a 2.31 gearcase. I think a 15" pitch might be better- maybe with a bit of cup added, maybe not. With a 4 blade and less pitch, hole shot will be good, as will low speed planing, which is nice for the rougher stuff in a 20. They say a 3 blade will give a bit more speed. I never tried-I rarely get to use 28 knots in Buzzards Bay. I run almost the same top speed, just 1-2MPH slower with a 17P prop, but much lower RPM and crappy holeshot.
I don't know RPMs for that engine, but I bet you are a bit low.
If you want to go faster, I wouldn't suggest a hydroshield with it's drag, but it does seem to keep a heavy 4 stroke and kicker on plane better (like mine). You don't have that problem with a light 115 2 stroke. The normal fins on top of the anti ventilation plate will help you get it up on plane faster, if you don't have one.
Nice looking boat!
