Old 04-15-2013, 08:10 PM
junior11 junior11 is offline
Default Paint: Easypoxy vs Brightside
So I worked hard, sanded, filled, sanded, gelcoated, filled, sanded, filled, sanded.... you get the idea, then finally primed. I had a tip to use brightside paint. I rolled the large areas and brushed the smaller ones with Pre-kote primer. That primer sucked. It was really thin, even without putting thinner in it. Also, anywhere it went on thick, corners, and any place where it even filed a little bit, never dried hard after a week of being inside. I tried to sand off and wipe all the primer, and it wasn't happening, so I was stuck. I did some research and found that easypoxy had better results. Also at this point I was STUCK using a one part. I sort of knew the results, but I tried to gelcoat over the pre-kote and it blistered and made a mess. I traded in my interlux products for petit products and the primer was much thicker, I thinned it slightly, and applied it. Within 2 hours at the same temperature, it was already starting to dry. It went on much smoother and was easier to work with.
Lessons IMO
1) Don't use a one part, as "easy" as it sounds, it's not worth it. Once you go down that route, you are never turning back. If you gelcoat or any other two part and don't like it, you could always put one part prime over it and go that route after.
2) If you are going to use a one part, go with the easypoxy over brightside.
I am not done yet, but I was pretty bumbed about the situation, but am feeling better about my chances of a decent outcome now.
