Thanks for the replies fellas. I forgot to post my own answer to the problem the other day. I found out that everything is ok except for a temp sending unit.
In the process of elimination I found the temp gauge sending unit to be off a little by borrowing a buddies thermal sensor or what ever its called. Nice tool to have.
I also found out that water and exhaust does mix at some point because water exits the exhaust idle relief ports as it always has; It would be nice for a confirmation on that Sandy. Go crank yours up and see if a little water comes out of those 2 holes beside the pee hole.
Thanks again for the replies...Richard
J. M. Hendrix
