Old 04-16-2013, 07:30 PM
Originally Posted by 76Red18 View Post
Thanks for the replies fellas. I forgot to post my own answer to the problem the other day. I found out that everything is ok except for a temp sending unit.
In the process of elimination I found the temp gauge sending unit to be off a little by borrowing a buddies thermal sensor or what ever its called. Nice tool to have.
I also found out that water and exhaust does mix at some point because water exits the exhaust idle relief ports as it always has; It would be nice for a confirmation on that Sandy. Go crank yours up and see if a little water comes out of those 2 holes beside the pee hole.
Thanks again for the replies...Richard
Water comes out the ports. First time I saw it freaked me out. Been thinking about replacing the head gasket o rings and " milling" the heads on some thick flat glass w/ 220. I am also concerned about the rubber t stat seats because they are a tad swollen and want them to open easily. What year is your motah Rich?
