The cavitation plate is about one inch above the boat bottom. 3rd hole but my transom was rebuilt to 25"ish so not factory specs. She is a 74 hull. If I had known where the motor would sit I would have built the transom higher than the 25 3/4" it is now.
If your running a Yamaha four stroke the 15 pitch Amita should get you a bit more speed/rpms but I was running a light load and 35mph at normal trim so we are pretty close I would think.
