Mine had the same taper. The sides are actually two pieces stacked on top of each other. The console had a little lip where the old windshield mounted. At that point I pegged it and straightened it back out so it was perfectly perpendicular with the ground. I glassed PVC to the back edge to give it stability and help mask this "kink". You can tell only if you really look at it.
