  #191
Old 04-30-2013, 08:04 PM
GoodChance GoodChance is offline
Originally Posted by Wildman View Post
Well, the mystery leak continues.... Taped over the thru hulls with Ductape for a few hrs this AM, and still had water in the bilge.
On a better note, changing the prop to a 15.75x15 and filling the front tank with fuel made it into a different boat! After wallowing around below plane before, it JUMPS up on plane and makes 30ish mph at 4000rpm now. It was really sloppy today and the boat handled it just fine. Tucked in close to shore in a short 2ft chop, twisted the throttles and let her air out a little bit and FLY, soooo smooth.
I gota get a nice flat day to check top end, wind jacked up to 20+ today by the afternoon. The spray rails work as it was a quarter head sea all the way home. The guy on the windward side got wet, but not NEARLY as wet as without the rails.
Question for you ....... why did you change over to a 15" prop? It seemed like you were over-propped at 17" and were planning on going to 19" and suddenly you were in a 15p. What happened?
I just completed a complete restoration of a 23 Seacraft with a full bracket. Power is a Honda 225. Right now I have a Honda 17p wheel but only making 4750 to 4800 rpm. I'm working with Ken at PropGods to get the correct sized wheel and we are probably going to first try a Mercury Enertia in 14 or 15p but wanted to hear why you ultimately chose a 15p? What make and model prop did you get? Mercury? PowerTech?
The Idiot Who Re-Built the Burnt-Up 35 Duffy
