Originally Posted by steve s
I have been doing my homework on here trying to find a thread that shows the splashwell liner removal so i can get access to the transom. i have cut the cap on both sides at the point were the tie downs pass through the cap and removed all of the screws that hold it to the hull. my question is, can i remove this in one peice so i can reinstall it after i'm done with the rebuild and if so how do you get it loose from the transom without destroying it? if not where would be the best place to cut it at the transom so it can be tied back in easily? this is on a 76 23' cc.
Good luck trying to get it out all in one piece. In my opinion the below deck live well is inefficient and gets in the way. A lot of us have installed above the deck live wells either in the transom cap or in a leaning post.
