Originally Posted by BrianH
Thanks Tom
I'm assuming I remove the glass ,clean the channel in the frame
fit the new gasket and put it on the glass
then set it in the frame and work the gasket into the channel?
Almost. You run a bead of sealant around the frame, set the glass, and then work the gasket into the channel. The gasket doesn't seal the window, it just holds it in place. I used silicone sealant on mine. No leaks so far.
Dave
