Old 05-08-2013, 03:06 PM
cdavisdb cdavisdb is offline
If its a two barrel, pretty minimal power. You would need to prop it for 20 knots cruise, maybe less. With a 4 barrel its closer to reasonable, but no speed demon. One good thing, torque is more important that HP, and I think, at cruising rpm, a 350 is a 350.
The boat is very sensitive to adding weight. Load it heavy, vacuum at cruise goes way down and I don't think the 2 barrel will work. For sure, get a vacuum gauge, or you are likely to eat the engine up.
My 350 is about 285 hp, with a duoprop and is near perfect for the boat if not loaded heavy. If I was going to load it down all the time, I'd need to reprop or go to a bigger engine.
