Old 05-20-2013, 09:45 PM
Jim,
A good friend of mine was also planning to buy a Sceptre 20 back in 1976. Then he went to the Miami Boat Show saw both the Sceptre and Seafari 20 side-by-side with the transoms up against an elevated walkway. Distance from bulkhead to transom is 10' on the Seafari and 10'6" on the Sceptre, so he was surprised to see how little difference there was in cockpit space. He ended up ordering a new Seafari! Although it was a little more expensive, he said the additional dry storage on the Seafari with nearly the same cockpit space made it a much better family boat, so the decision was a no-brainer for him. His planned use was the same as yours, just fishing and a day boat. I don't think he ever did any cruising or camping that it's also well suited for.
The one advantage of the Sceptre is easier bow access, which might be a big deal if this is your first boat, but it's not a show stopper in my mind. The key is to simply have permanently mounted bow lines running back to the cockpit, so they're readily available when you come into a dock. It also helps to have an anchor chocked on deck with a deck pipe leading to the anchor locker so you can get an anchor down quickly. A bimini top that's braced off the windshield so it makes a rigid handhold is a big help if you want to walk around the cabin to get on front deck, which is quicker than going through the cabin and front hatch. It also helps to have some breast cleats mounted amidships adjacent to the helm, so you can secure a dock line by just reaching over the side windshield to the cleat.
Although both models were only built by Potter and Moesly and are relatively rare compared to the thousands of CC's that were also built by SeaCraft Industries and Tracker, the production numbers show that they only made 263 Sceptres and 741 Seafari 20's, so your odds of finding a Seafari are about twice as high as finding a Sceptre! Most folks seem to want a CC model however, so either one is typically cheaper in the used boat market than a CC model. Good luck with your search. Either one makes for a very versatile family boat! Denny
