Old 05-25-2013, 04:54 PM
motor is mounted too low, as Denny said creating both problems, thats why the dealer said trim it up but thats not the real issue he should have mounted it higher - cav plate should be 1 1/2" to 2" above the hull bottom with that prop its a good prop - not exact as each hole is 3/4" but at least 1 1/2. you can measure it with any straight edge, wood or PVC
