Adam, if you're rigging a boat with a bracket, instead of just running everything out the transom and across the swim platform, it'll look a lot cleaner if you run the rigging thru the flotation tub and then up through the swim platform. That's the way Don Herman and Caymanboy have rigged their brackets, and Don sells rigging kits for it. (You'll need an access plate in top of bracket to do that however.) Denny
