There are other concerns that have been mentioned. One of the things I like about running premix is you are almost fogging the motah at idle on the muffs. All of your gaskets and seals are dry now. Rings, cylinders, and roller bearings as well. Dry is unhappy and possibly rusty as well. Get a good atomizing spray bottle and open the carbs. Drop the trailer tongue and tilt the motah all the way up. Fill the bottle with marvel and crank the motah. Shoot the intakes for a good while with no spark. Get her good and wet. Let her sit so the gaskets can swell and loosen any corrosion to soften the effects of hibernation.
