  #248
Old 06-19-2013, 05:52 AM
Originally Posted by Calibogue View Post
Your lenco actuators mounted through the bracket!
I will need to do the same for them to fit and get the bracket height correct.
How much rise did you use per inch of setback?
For every 12" of setback, I raised the engine an 1", or should have.
I am happy with the bracket height, it is down low enough that I get a good portion of the flotation values, I can still mount lights, thru hulls, etc, thru the main hull and it is a good height for boarding.
But I feel the engine could go higher, so I will raise it a notch.
How is your project progressing?
I thank everyone for their kind comments.
It appears as if the wind Gods may have changed their minds, the first forecast for this w/e was ESE 15-20knts, little too sporty for my taste in this boat. Now that has been revised to 11-14knts, if that is the case, I'm ouuta here!!
Final touches going on, TUUCI Top, etc.
Last is the cooler, spear, rods, fins and TM/LLL II. :-)
1972 20' SeaCraft SF, F200XB
1974 40' Eagle
www.parkeryacht.com
