Old 06-20-2013, 08:32 AM
TooFly TooFly is offline
Originally Posted by BigLew View Post
What is the height of the intended mount above sea level? Figure that 1/2 the 3.9 degree angle of the beam is 1.9 (or 2, for simplicity). Look at it as a right anlge triangle and figure the
distance out ahead of you that the beam hits the surface of the water. That will be the nearest distance your radar will show on the water surface. Check your trigonomety equations. Sine = opposite divided by hypotenuse, cosine = adjacent divided by hyponteuse, and tangent = opposite divided by adjacent. The angle value you use 1.9 degrees. The right traingle is 90 degrees, 88 degrees and two degrees. You should know the height of the radar dome (mounting height). Any problem ask a high scool student who has had trig!
Isn't 48 miles a little overkill for a 20' boat?
Trigonometry? I hated trig... liked AP Calc even less. But then, I didn't very much apply myself none too much needer. The wife LOVED trig and she's going back to school, I'll get her on it right away!
Nah, man. The more range the better. Plus this Radome has "bird mode." I'm really looking forward to that.
1969 20' Potter SeaCraft
2007 150hp Evinrude E-TEC
