Thread: Interlux primer
Old 06-20-2013, 12:41 PM
Default Interlux primer
Has anyone up here used the Interlux InterProtect 2000E Epoxy Primer yet? It suppose to be good for above the water as well as below the water line. It has micro plates that coat the fiberglass and works as a barrier coat against water intrusion and prevents blisters. I am not bottom coating my boat and want to get protection against water absorption. I am not planning on leaving it in the water over three days at the time. I know it can be covered without sanding but I plan on block sanding it down to slick it out. Anyway have any csc guys used it and do you like it? Is it easy to sand? Dose it spray well once thinned?
