Suggestion - use WAY LESS pigment than you believe appropriate- just a tiny drop.
Then mix very thoroughly and first compare to the untinted gel coat in the can.
You'll be surprised that it will show the impact of such a small tint.
Then put a little dab on the boat - see how it matches up. Add a very tiny bit more tint if needed.
Over adding color is WAY easier than you'd think.
