Well after spending countless hours on my back in weird positions. Terminating at least 40 wires then heat shrinking them, labeling now I can finally say that the dash is 95% wired (you can never say 100% cause you will add something sometime
Stuff all over the place.
Behind Dash
Switches wire and labeled.
I let the natural torque of the wire load level the body of the switch to where it wanted to sit. Since you can't normally see it, who cares if they are not equal.
Fuse box with and without cover.
Dash and Switch Panel
Now to drill another hole in the bottom and install my transducer and run one more wire to the front...
Everybody out there enjoy the holiday...Happy 4TH!
