Thread: seafari 25
Old 07-15-2013, 09:13 PM
Food for thought.
She is a drivers boat.
Sandy is right. This is not a boat for someone who doesn't have a good grasp of the physics of boat handling and a desire to use that knowledge to optimize his seamanship. I was a little startled by the amount of heel in a turn when I first launched mine, but now that I'm used to it, it's kind of fun to play with. I can lay her over in a turn until you feel like you could dip your fingers in the spray off the chine from the helm seat, or I can add reverse tab and make sharp turns without banking into the turn at all.
I don't mind using the tabs to keep her running level, but it's not necessary unless there's someone moving around the boat. Connor is right about the heel response to minor turns of the wheel and how that makes it easy to land on the next wave the way you want to. Definitely a driver's boat, and about as nimble as you'll find in a boat of this size.
All that being said, I agree with pretty much everything the other 25 Seafari owners have said. I think the 5.7 MPI Mercruiser or Volvo Penta is the right power for the boat. I have the 350 Mag MPI and a Bravo 1 drive and can cruise comfortably at 30-33mph with a top speed of 40-43mph depending on propping and load, and a minimum planing speed of about 13 mph.
The Bravo 1 does produce a little torque heel out of the hole, but it goes away once you get on plane and trim the outdrive up a little. I would like to move to the counter-rotating Bravo 3 , but it's hard to justify the cost when the Bravo 1 works just fine.
Dave
Blue Heron Boat Works
