Old 07-20-2013, 09:38 AM
Originally Posted by pelican View Post
if your boat required a lot of filling and sanding after the blasting process -you had one of 2 things going on:
first,the blasting process was way aggressive
second,the boat had damage /blisters under the antifouling pant
I think if you look at the pictures you would be wrong in both cases.
First off any hull 50 years old is going to have voids, which the blasting will find.
Second the age of the gel coat heat and cold will cause a whole different set of problems.
No matter which way you cut it, you will still have a lot of work to do.
