Old 07-22-2013, 07:30 AM
I will add two layers of of 1808 over the 3 layers of mat to add a good bit more of strength. After getting this far and hot coating the matted layers in the 95 degree heat in direct sunlight. I had to work faster than I like to do due to the cure time. I mix in smaller batches and stuck with the 1% hardener (normally use more to speed up cure time) and decided to let it cure out after the first few layers. I will ruff it up with some 36 grit sand paper, clean it well then add the 1808 and some more tabbing. This time I will do it a bit earlier and beat the heat.
Last edited by flyingfrizzle; 07-22-2013 at 11:04 PM. Reason: 1808 not 1708 (used stitched mat)
