Old 07-27-2013, 05:43 AM
oldfielder oldfielder is offline
I am seeing almost identical numbers in terms of speed with the same engine drive combo. My top end is right around 40mph and my cruise is slightly slower than yours at the same rpm. Sounds like I am a bit heavier in terms of hull weight with gear.
Are you sure the max rpm range isn't 4400-4800?
I will check my prop size when I get home later.
