Thread: (no title)
Old 09-11-2013, 11:41 AM
http://www.fibreglast.com/product/du...-coat-additive
Mix it with white gel coat. Roll it on.
I have noticed you use a lot of Duratec products and was looking in to their Vinyl-ester primers. I was wondering if you use their fairing primers before and how did you like them? I was thinking about getting a gallon of the VE primer to coat my hull with for block sanding and fairing. I would like to get something that I can spray on thick that will cover those pesky little pin holes. Also I think it would be good far as keeping all the chemicals VE based. I been using the 3m VE underwater line type puddy and been coating with a epoxy primer. My thoughts are that the more similar chemical make up I can keep the better. The epoxy primer might do better for water proofing but the duratec VE primer should do about as good as what Im using now. Also dose the duratec sand well and what do they recommend for thinning it?
