Thread
1974 20' sceptre transom replacement and i/o to outboard bracket conversion
20
09-18-2013, 07:17 AM
flyingfrizzle
Set the bracket last night. Got it as low as possible for maximum flotation. The tub ended up 3" above the boat keel and the motor mount was about 29" from the boat bottom. I think I should Be able to get the motor up 4"-5" no problem. The swim platform is not as low as I would like it but it had to be higher like this to allow for the lower motor mount bolts to hit below the platform to get the required height. Looks good on the boat. I will be using flat bar to back the bolts on the inside and also changing the current bolts to ss carriage bolts to give a nice rounded head that will be seen on the lower flange due to the reverse direction of it. The flange will need a half circle cut out in the bottom to allow the drain hole to be accessed as well. Now that the dry fit is done I will make some small changes and get it prepped for a final install.
flyingfrizzle
View Public Profile
Send a private message to flyingfrizzle
Find all posts by flyingfrizzle
