I am trying to avoid epoxy when I can. It is a sensitizer, and I have used too much of it already. I can still work with it, but I can see the day when I won't be able to.
Plus polyester doesn't stick to it well, if at all, in case I want to laminate structure in there in the future. Although I suppose in either case I would be abrading away the surface.
Strick had mentioned a duratec high gloss gel coat additive- I might try that. I have a gallon of white to use up.
