Old 10-04-2013, 07:51 AM
Photo Bucket has my account pictures froze due to the 10k band with rule and hopefully the pictures will be back soon. But here is some progress till then.....
I got the section I built to fill in the old i/o hole for the floor installed. I used thickened resin on top of the stringers and sat it in place. Once that set up I came back and sanded off the sides of the new section and around the old deck at a 45 degree angle both ways to make a pocket 2" wide and 1" deep in the center to lay new glass in. It took about 12 layers or so to build it up past the deck height by starting with thin strips and getting a little wider each time. Once that was done I sanded it back flush and then hit it with some resin and 407 west additive I had laying around to smooth it out then shot it with white epoxy primer. I will go back and add the deck stripes during final paint process to match the rest of the deck.
The rear top cap has been sanded, faired, and primed with epoxy primer and now is being installed back on the boat.
