Thread: Fuel Tank build
Old 10-04-2013, 09:11 AM
pelican pelican is offline
Originally Posted by Normagain View Post
I think fuel tank installation is pretty tough really if you want it to last. When I took the tank out of my 74, most of the hold down points were at or near failure. My tank was solid but the fuel fill hose was rotted through and you could see the damage spilled gas had done to the plywood sheet under the tank, loose in two places and soft. There's a lot of motion to the ocean so over building a system to hold it in place is a really good idea. I had the tank builder add two extra brackets and I used 1 1/2" of plywood at each point, two screws instead of one + epoxy. Hopefully that will keep it there. I'm less worried about corrosion to the bare aluminum, should be good for another 40 years.
very true - people are often unaware of the "accepted" procedures...I've seen some interesting ways boat owners attempted to install fuel tanks - using pool "noodles" as a method of securing the tank...
another thing is,people are trying to cut few corners and save some money - this often leads to trouble down the line...
bottom line : this guy did a butcher job of a fuel system lay out,from the tank material on down...
