Old 10-06-2013, 03:13 PM
bigeasy1 bigeasy1 is offline
1708 stitchmat is fine to use with epoxy as its stitched, there is no binder in it, so no need to worry about having to dissolve it.
I used 1708 on all my hatches, but I ended up using polyester resin.Alot of my glass work was done in cold temps and I found the polyester resin an advantage when getting it to kick and cure pretty fast and properly.
I was able to apply it in the cold and then crank the heat up .I didn' t have the luxury to leave the heat on for long periods, which I would have had to do with epoxy, even using a fast hardener.
All this,just for a boat ride
