Old 10-13-2013, 08:35 AM
Originally Posted by sidelock View Post
You fried that battery with the battery tender. DO NOT use the tender on your new AGM batteries because you will fry them too. Get yourself a good quality proper charger to handle AGM's.
Is this true
This is what there short description says:
The 2 Bank Battery Tender® Charging Station is two encased 1.25 amp battery chargers designed to fully charge a battery and maintain it at proper storage voltage without the damaging effects caused by trickle chargers. This charger will operate anywhere in the world!
2 independent charging stations.
12 volts @ 1.25 amps per station.
Extremely lightweight! Less than 3 lbs!
Operates anywhere in the world! 100-240 VAC 50/60 Hz.
25 ft leads available (NOT INCLUDED).
Microprocessor controlled constant current charging!
Reverse Polarity Protected.
Spark Proof.
Perfect for all AGM (absorbed glass mat), sealed maintenance free and flooded batteries
Complies with US and international safety standards (UL/CE).
2 year warranty!
