Sounds like you have a short in a wire somewhere. One other time it beeps is when the key is turned on, then the alarms mentioned. It could be loosing power for a split second and makes the beep at that time from a shorted wire or bad key switch possibly. I got the same motor a the house and have the book with the wire diagram if you need it. It shows alarm circuts...
