Old 11-28-2013, 05:11 AM
parrott parrott is offline
Some more progress. Foam is glued in. Also cut some foam for under the deck. Gonna use a kodiak baitwell mounted on a stand. Seems it will make things alot easier and you want have to worry about water splashing on your back. Cut some pieces for supports under the gunnels and some rod holders. Pulled some 202 over the glass to give me something to sand so I can make the box somewhat smooth. Think I may cut a hatch in the back bulkhead so I can access the other side of the baitwell and also put a high speed pickup and seacock valve. Thinking the further up from the motor the less disturbance it will cause.
