For the MA box stringers running some 2x4s cross wise will raise the floor. You could laminate plywood together outlining the box stringers to prefered height or even cover the whole stringer w plywood and laminate to height you want. I did the 2x4s on my last MA. Raised the floor 4" and worked out perfect. May want to go alittle higher since you are already raising the floor. I used 3/4. 1/2 can work but no more $$ 3/4 is I wouldnt go w 1/2.
Check out my rebuild on here under "parrott" and "seacraft84" usernames
