Old 12-04-2013, 08:34 AM
Thats an interesting looking seacraft. Did someone play with it before you got to it?
I had been redone a few times before from the way it looks. The rear seating was removed and gone. Look like there will be more room behind the leaning post with the plain basic transom lay out that was put back in. Some one recored the floor, well about 2/3 of it. They left the old balsa wood around the edges of the deck and only changed out the fuel cover and a foot down both sides of it with 4" ply wood squares. Later on the transom was looked to be done after wards and the last two foot of the deck at the rear was cored with a solid 1/2 ply at that time. Some one cut 4"x6" holes in the top of the stringers and refilled sections with foam. Not all of the foam but just enough for them to say they did it. There were several layers of white paint & gel coat on the deck where it had been refinish several times. Transom is raised to 25" height. Here are a few pics before I got the sawzaw out:
