Old 12-10-2013, 11:39 AM
conchcuzzy conchcuzzy is offline
Zachary, that's correct 77.5" between and 66" tall. I will confirm the width measurement today making sure the uprights are not squeezed or spread. Bear in mind the 1978 18sf has wider gunnels than earlier models so you may need an inch or two wider Bimini frame to depending on your configuration. I will also get you the open measurement.
