Old 01-04-2014, 01:26 PM
Originally Posted by Bryan A. View Post
Looks great.
Looks like you moved the wheel and throttle around. How did that work out. I need to do the same, but would like to keep the "glove" box just as you did.
What size wheel did you use?
If I had left the wheel where it was it would have been really close to the Yamaha throttle, especially where the trim is locate. I moved the wheel only (the throttle was on that side) and bought a smaller diameter wheel so the glove box would open without hitting the wheel. I like the smaller wheel, 13.5" instead of 15.5" quite a bit! I would check to see if the 13.5" would give you what you need instead of moving it. I probably could have managed that looking back but I do like the location better. I moved it up on the console slightly also.
