1975 SeaCraft 23' Tsunami Potter Hull $4500
Hull ID# SECR3001M75A
Twin 4.0 Mercruiser 165 HP I/O's
Port Motor:
- Head has already be redone by NAPA have receipt
- Possibly needs starter
- Needs New Carb
Starboard Motor:
- Needs New Fuel Pump
- Needs New Carb
I have parts still in the box for these motors:
New Distributor Cap Kits for both motors
New Spark Plug Wires
New Spark Plugs
New Fuel Separators
New Misc Outdrive Gaskits
New Motor Oil
New Outdrive Oil
New Battery
I have already replaced the following:
Both Outdrive Water Impeller Kits
Both Thermostats
New Bimini Top
New Lee Outrigger Kits
I was going to get this boat running but have decided to switch to Center Console instead, will separate from Trailer if needed.
I have more interior parts like the inside cushions and entry door into the cuddy. I have teak trim pieces that may be missing in the pictures.
$4500 with 2001 Heavy Duty 9000LB Load Rite Aluminum Trailer
$3200 without Trailer
Contact: Chris 772.528.0840
Located: Stuart, Florida
