Thread: Foam Questions
Old 03-01-2014, 06:21 PM
For floatation, use the 2lb foam. You'll get the same buoyancy for half the cost and half the weight. The heavier foams are structural, for use in casting or sculpting applications where durability is more important than weight or buoyancy.
Dave
I agree with Dave - SeaCraft never depended on foam for strength, it was for flotation only. The original Moesly 21 and maybe the 19 Bowrider, which is the same basic hull as the 20, were built in the 60's prior to the USCG flotation requirement and had NO foam, so they're obviously strong enough without it. Why use the denser foam which will actually provide LESS net buoyancy when the whole purpose of using foam in the first place was to increase buoyancy! The main thing I'd check is to make sure it's closed cell foam, to minimize water retention if it ever does get wet.
