Originally Posted by CHANCE1234
These are the chips in the fiberglass I'm talking about. Everyone one of them are on the hull steps the length of the hull. Now what's the best way to fix em? . . .
Chance, that white Fasco epoxy I recommended earlier in post #45 would work well on those dings. I had quite a few dings like that. It's less than $30 for a quart and is about the same hardness as gel coat when cured, so it sands real nice. If you look thru the pics of the sanding and fairing slideshow of my bottom painting project in the earlier post, you'll see that I used it all over the bottom to fill nicks, dings and low spots. I put Interprotect over the whole bottom to seal it under the paint, but if you plan to sand Interprotect before painting, do it the next day! It continues to harden and if you wait a week, it'll be like sanding granite! Denny
