Originally Posted by slowJEEP
-US Composites Thin, Slow 635 Resin thickened to mayo consistency and slathered on Coosa and inner skin.
-Bolt together and let it setup.
Go to Home Depot or Lowes and get one of these to do your "slathering":
http://www.homedepot.com/p/QEP-1-4-i...0113/100192636
It will give you an even distribution of thickened epoxy that will squish down (technical term) nicely to give a uniform bond coat.
Phase 4
-Overdrill holes/fill/redrill for engine mounts, scuppers, etc. (maybe do predrill ahead of time to make things easier?)
Overdrill and fill is a technique usually used for wood cored laminates as a method to isolate the wood core from any moisture that might enter the drilled hole. It is unnecessary when using inorganic cores with adequate compressive strength. Coosa 26 has a pretty high compressive strength, so you can skip this step. Do what the stretcher of fishes said and use large washers or plates to spread out the compression load from engine bolts.
Good luck with your project,
Dave
