Originally Posted by hermco
. . . Bill Potter says the bracket will provide performance benefits and better fuel economy over a hull extension. I guess Carl M. disagrees. I don't know as I don't have before and after data on the same boat using both concepts. Obviously the bracket is the cheapest, easiest way to go.
I think Potter has a very narrow definition of "performance benefits" that are theoretically possible but not practical. Most brackets shift the CG aft by significant amount unless you compensate by moving batteries, consoles and gas tank. Shifting the CG aft will no doubt raise the bow and allow you to run with more hull out of the water IN CALM CONDITIONS, so that would reduce drag and theoretically allow a slight increase in speed and MPG. However my "real world" experience with a boat that I ran with a light motor for 31 years and then repowered with bracket and much heavier motor (and there's no console to move in a Seafari!), was that the resulting CG shift increased my min planing speed, even with trim tabs, from about 12 mph to the low 20's! Yes, I could hit almost 50 mph with the bimini top lowered, a light load and a good 3B prop, but I never use the boat like that! Since I seldom run in flat calm conditions, but mostly offshore where you'd like to hang on plane at low speed to keep from going airborne when the seas kick up, that increase in min planing speed was totally unacceptable! By the time I added a doelfin and stern-lifting 4B prop to get my min planing speed back down to 12 mph, I LOST about 10 mph in WOT speed, and I know the doelfin costs me 0.2 - 0.3 mpg from back-to-back tests! A good friend of mine re-powered his Seafari with the same motor I have but without a bracket. His min planing speed is still relatively low, but his WOT speed is 50 MPH! Bottom line is that I think my real world performance would be better with the motor on the transom!
Now with a CC where you could maybe offset the CG shift by moving the console, gas tank and batteries forward, you might be able to still get the low planing speed with a 3B prop and no fin. The bracket does add other benefits like the solid transom, big dive platform and more room in the boat, so I would still do it again, but I have to admit that Carl was right, extending the hull would have been even better, giving the same benefits but without causing the CG shift and related problems! He has years of racing experience in rough conditions that Potter never had, so I would trust his judgement over Potter's any time! And the hydrodynamic model that Dave refers to also predicts better low speed planing performance (='s better ride!) for the hull extension!
