Originally Posted by bigeasy1
. . . I sprayed my 18' aluminum boat with a linear urethane by the name of Sunfire.It's a two part urethane similar to the others like Imron.It's made by Sherwin Williams and sold only through their automotive supply and industrial supply houses.It was used a lot in the airplane business.
I was told by the clerk at the auto body supply house that a standard cartridge respirator would be fine to use,so that's what I wore. , ,
John,
Sunfire is an industrial grade urethane that appears to be the same stuff as Signature Finish, except that Tom Fabula can mix it in any color you want as opposed to the limited color selection available from Sherwin Williams! I think a standard charcoal cartridge filter is OK for roll & tip is, as that's what I've used with it with no problems. Tom doesn't seem to offer a lot of support for spraying it, and I can see how the fumes could be a lot more toxic when sprayed.
