Old 04-09-2014, 11:30 PM
martin martin is offline
Flex,
I am just going to outline the void area first. By rapping on the fiberglass with a small hammer. Once done. Drill a small 1/4" hole at the bottom and another one at the very most top.. I will pipe tap the holes and install fillings with valves.. Mix resin and vac at the top and pull resin from the bottom. Once filled cut flow from the bottom and pull a slight vac from the top. Till cure... I will use a fast cure to about 30-40 min. I will take pics...
