Now that it is finally warmer out I cleaned up the bottom of the sceptre and shot some more primer on it. I already had 3 coats of interlux 2001 epoxy barrier primer and went with a coat of white interlux epoxy prime coat over that. I will fix all the little spots and pin holes with an epoxy glazing putty and then it will be ready for polyurethane paint on hull bottom.
