Old 04-11-2014, 11:24 PM
had sometime tonight to mess around with some stuff. I got the garboard drain drilled and got an layer of mat inside it to seal it up. I decided I wanted the gunnels wider in the rear so I scribed a line an made a cut. I made it 1.5" wider in the rear. I got it all fastened back together and ready for the flip.
alright I got back to the laminating table. I got the stringers all squared up and put the melamine down on it. either I am getting weaker or the melamine is getting heavier. Its got to be 90lbs a sheet with razor sharp edges!! The table is big. hard to tell in the photos, table is 8'x 18' edges all lined up and still have the 1/4" depression which in return will be a 1/4" crown for drainage.
pulled a string down the center and shot some finishing nails to secure everything.
straight edge across the deck showing the dip.
till next time
36' Yellowfin
1972 20' seacraft 140 suzuki
