Thread
1974 20' sceptre transom replacement and i/o to outboard bracket conversion
4
04-11-2014, 11:48 PM
flyingfrizzle
Sanded down with 320 and done another round of fairing. Removed the brass floor drains and ground around the hole 6" each way. Went fairly deep around the hole and tapered it back good. Cut a plug to back the glass. The wood block tying the deck to the hull on the drain was solid as the deck is. Laid several layers of glass starting small and working my way up till I had it a eighth above the hull. Will grind it flush tomorrow.
flyingfrizzle
View Public Profile
Send a private message to flyingfrizzle
Find all posts by flyingfrizzle
