Originally Posted by dave s
Laid the core back in at 5 degrees instead of the original 12 degrees to see how the bulkhead will look.
Prefer a more vertical bulkhead for more toe room and not to lean out when braced in the back.
Also this allows me to make the transom cap narrower. . . .
If you're hanging motor on transom, that shouldn't be a problem. However if you decide to install a bracket, just be aware that it will have to be a custom job, as most brackets are not built for the oddball 5 degree angle!
